The 3mf is not from Bambu Lab, load geometry data only
Can anyone help me understand this error message or any way to avoid it? Does it mean that Bambu Studio will never allow 3mf files from Thingiverse/Thangs/printables/etc?
Consider it as ‘information’. 3mf-files are generally sort of an archive file format. You will see that message when the 3mf was not prepared / saved by Bambu studio and therefore may contain information not processable by BS. Nevertheless, you should be fine loading the model, set your settings for slicing and resave as 3mf.
This is one of my pet peeves about Bambu Studio. They shouldn’t have appropriated the .3mf extension. I don’t care if they use the .3mf format internally, just use a different extension for projects so users don’t accidentally overwrite a model with a project (as I have done). There will also be no need to ask the user if they want to load the .3mf as a project or geometry only because there would be no ambiguity. The other thing I hate is when loading a model freshly saved from Fusion360 as a .3mf file, it asks if I want to replace settings. Where are these new settings coming from? I’m pretty sure Fusion 360 doesn’t even know to add Bambu Studio settings to a .3mf file. So are these settings just random values accidentally stored in locations Bambu Studio uses? This whole saving projects as .3mf files is confusing not only users but to Bambu Studio itself.
i did this however it seemed to lose the color changes in doing so.
This needs to be fixed ASAP. Loading a .3mf file and accept geometry only results in all the color changes be removed.
That’s what “Load only geometry” means…
But if you don’t load geometry then some of the parts of the object are remove during import. Load geometry is the only way of have the entire object imported but
You lose the colors.
Hello Bambu Labs, can you please REMOVE the unnecessary message dialog [The 3mf is not from Bambu Lab, load geometry data only] as it is not required and information.
Have they added option to disable this useless ■■■■?
I would also like to see them remove of this silly requirement too. Do they own the format? Is it a security issue, or, as I suspect, simply a marketing tactic that will drive more business to their domain?
just have to convert stl to 3mf and done
