I’m entering this into SW because I believe it’s this n00b using the wrong settings. I have searched and tried all the resolutions I found with no luck.
I have successfully printed several of the items pre-loaded onto my new X1 Carbon with AMS. I have failed with an STL I made and sliced with Bambu Studio, and I have failed with three different objects DLd from MakerWorld. All failure were notifications that " [The current build plate is not the same as in G-code]" I’ve tried hard to look for settings regarding the build plate and found two. One on the upper left of the Preparation Plate… and set to “Bambu Lab X1 Carbon 0.4 Nozzle”, and the hexagon with a small circle inside on the right of the image of the build plate, and changed this from “Same as the Global Plate type” (I actually tried leaving this setting) to “Cool Plate/PLA Plate”.
Despite the screen capture I have used the green PLA basic as per the download requirement.
FWIW, one of the objects is: Shamrock Bouquet by J3DPS - MakerWorld
Thanks immensely in advance.
JD
