Just got this error when trying to run Bambu studios. I uninstalled and reinstalled the app and no change. BambuStudio.conf cannot be deleted.
Anyone know how to fix this?
thanks in advance,
Gordon
Boot into Safe Mode & delete it.
Rebooting will probably be sufficient. The file is locked because there’s an orphaned process somewhere with an open handle to the file. You can’t delete it because the OS thinks another program has it open, still. Rebooting will kill that orphan process. Simply logging out and back in to your Windows PC might do it, too.
You can also use Window tools like Process Explorer to find all the running processes that reference a particular file, and then kill those processes, which is often all that’s required to be able to delete a locked file.
That fixed it! thank you so much!
thanks for the input. I started in safe mode and then deleted the config file.
thanks!
