The ptfe tube between buffer and right extruder
I had a clog and I had to cut that tube about 1/2 Off. Will this effect the extruder or cause an error. Reason I’m asking is after I did this. I ran a 8 hr print. Next morning I went to run another and got this error.
Z axis homing failed; the task has been stopped.
10300-4000 051528]. I followed the best I could to fix it. But am scared to mess with cables. Because of Hands shakes.
You can choose the length of PTFE tubes external to the printer.
The only real limitation is if the change to the filament path goes through tight angles that can break or snag the filament.
For example, you could take a length of PTFE tube and cut it down to make an AMS closer to the printer. Shrinking the distance increases print times with colour changes, as the length of the PTFE tubes is the travel path in and out of the printer.
Provided you didn’t damage the PTFE tube or make it too tight when you cut it down, it is unlikely to be the cause of the issue.
Z-axis homing issues can be caused by filament which is cut by the printer falling onto the back of the printer and getting jammed when the bed is lifted.
Another reason: Homing Z axis failed - Heatbed and excess chute interfered | Bambu Lab Wiki
It takes place during the home set up. Plate is in the middle of machine. Can’t load video. Sorry
Upload to a Youtube account, leave the URL as private.
The video will be public, but not searchable.
We can then see it.
issue has been resolved thank you Replacement unit sent
