I had a problem with some small parts falling off the rear left corner of my bed. This surprised me, I wasn’t sure if it was due to the Aux fan, so I took a thermal camera and took a look at the bed.
Wouldn’t you know it, even with the Aux fan off, there’s a cooler spot! With the Aux fan on, it’s more pronounced as the fan helps to cool that area.
Attached are some images of what I’m seeing. I circled the cool spot in black.
Depending on when you capture the thermal image, the cool spot can be from 2 to 4 degrees cooler than the rest of the heat bed (or your build plate).
Of course, letting it heat for a longer period of time brings the temperature difference of the cool spot closer to the temperature of the rest of the plate due to heat soaking, but it’s always cooler than the rest of the plate even after several minutes.
At first I thought the issue was only due to the fact that the Aux fan seems to concentrate its airflow in this corner (looking from the front door, it’s on the left rear corner. But after making tests with the Aux fan off, I see it seems the bed has a cool spot.
I don’t have a contact thermistor to double check this yet, but perhaps I’ll get one for testing.
Note that the orientation is not the same for all of these photos due to the way I was holding the camera from various angles, but the circled spot is the same location, looking in from the front through the door, the cool spot is in the rear most left corner of the heat bed.
I’m not sure if I have a defective bed or not? Perhaps I should enter a support ticket?
I’m open to any and all ideas. This may not even be a problem, perhaps this is within their normal specifications for the heat bed?
