Thick walls in Vase mode
I downloaded a file from printable for a cool looking vase. It’s meant to be in case mode which only prints extremely thin walls. I was wondering if anyone knew how to print it with full thick walls. Thanks
Vase mode comes with a single wall restriction, and thus, either you increase the line width (check the flow rate):
Or use a larger nozzle.
E.g. with 0.6 mm nozzle:
Another option is to print without vase mode and increase the number of walls to achieve the desired thickness; just set the infill density and number of top shells to 0:
I tried printing without vase mode but the case is solid on top then I’m pretty new to this so I don’t know how to put the hole in the top lol
Does 0% infill do what you want?
Did you set the Top shell layers to 0 like JayZay showed above?
That works for me.
You could also use the cut feature to trim off the top few layers.
THANK YOU!!! This helped this noob so much!!!
