Thin Wall Printing for 3d printed Airplanes
I have a free model of 3dlabprint.com. They provide the 3mf file for prusa slicers but this file is not compatible with bambuslicer.
Any solution idea ? Anyone can print eclipsonairplanes or 3dlabprint airplanes ?
Orca Studio supports *.3mf, *.stl, *.stp, *.step, *.svg, *.amf, *.obj files.
Can you download them as one of the other ones?
Orca Slicer gives the same error modal.
But can you download the files in one of the other formats I have listed above? Besides *.3mf.
The message means only, that all printer and slicer settings will not imported, but the geometry data will be loaded. You can load and then slice it based on your printer and filament settings using Bambu Studio or OrcaSlicer. :slightly_smiling_face:
Actually we can use 3mf or other formats but these files have very strict settings to print. All of these settings created in 3mf file for prusa slicer and they provide Cura profile too. I prefer to use provided file with settings. And maybe i can use prusaslicer and find these settings and set them in bambustudio ?
Yes this is the way to go, because Prusa Slicer has no Bambu Lab profile. You can also generate a profile for your Bambu Lab printer in Prusa Slicer. Than you can generate the gcode file and print it using a SD card.
Just select OK and it will load the model. The settings from another slicer would not be correct anyway.
I was struggling with thin wall printing for my 3D printed RC airplanes — walls were too weak, parts were delaminating, and slicer settings just weren’t giving me good results. Lightweight parts like wings and fuselages were coming out brittle or messy.
I reached out to Rapid 3D Technologiesand they really helped. They guided me on:
  • Proper wall thickness and line count (usually 0.4–0.6 mm with 2 perimeters)
  • Tuning temps and speeds for PLA+ and LW-PLA
  • Optimizing slicer settings to avoid gaps and improve layer bonding
Now I’m getting clean, strong, and lightweight prints. Just wanted to share in case anyone else is dealing with the same thing.
