Happy to.
The most obvious thing you can do is count them, there are two hot ends, while the mechanism can swap out 6 docked nozzles into one of the hot ends, there are still only ever two that can print at any one time, and even that is true.
It is worth noting the differences between the main printer types currently popular, this list is not exhaustive and ignores types that have fallen out of favour:
- Single nozzle, examples: A, P & X series, and H2S.
- Dual nozzles (one at a time), examples: H2D & H2C.
- Dual nozzles (can operate at the same time), examples: true IDEX like Tenlog TL-D3 Pro (I used to own one).
- Tool changers (one at a time), examples: Snapmaker U1 & Prusa XL.
We will use the term Nozzle to denote the place where the filament comes out of the printer to form the model.
We will use the term hot end to denote where the nozzle is attached and accepts the filament come from the spool, however that is achieved. This is simplified for the example as the tool changers blur the purpose.
For your question we need to look at point 2, specifically the H2C and a tool changer, we will keep the U1 in mind.
When you print using either solution, only one hot end (differentiating between hot end and nozzles) actual extrudes any filament, when the other is used, the other one is not used. When a tool changer works, only one of any ‘hot end’ is used at any one time.
When a tool changer is in the mix and in its most basic setup, there is a one to one relationship between the filament you will use and the nozzle that will extrude it. Assuming, you have red, green, blue and yellow this is the process of swapping between red and green and back to red again.
- Dock the tool with red
- Attach the green
- Use the prime tower
- Continue printing
- Dock the tool with green
- Attach the red
- Continue printing
Now the same process with the H2C, we will assume red is on the left toolhead and an AMS is hooked up with green, blue and yellow installed.
- Load the left head with Red
- Cut the filament
- Poop
- Continue printing
- Swap heads to the right head
- Grab and dock the nozzle associated with the green filament
- Load the right head with green from the AMS
- Remember to wait for the filament to be pulled through the PTFE tube to the head and into the nozzle
- Cut the filament
- Poop
- Continue printing
- Swap heads to the left head
- Continue printing
The H2C has 1y steps, the tool changer has 8, a 100% increase. This simple example doesn’t show the difference between how each type swaps filaments, with the H2C already much slower than the tool changer as no filament was pulled from the AMS with that.
Some simplified swapping times are as follows: 45 seconds for the right nozzle each time there is a colour change on the H2C and tool changers are 15 seconds. Both of these are subject to fluctuations based on the exact scenario in use.
Now, let’s swap through some more filaments.
Tool changer:
Red > Green > Blue > Yellow > Red
- Attach the green
- Continue printing
- Attach the blue
- Continue printing
- Dock the tool with blue
- Attach the yellow
- Continue printing
- Dock the tool with yellow
- Attach the red
- Continue printing
H2C:
- Cut the filament
- Poop
- Continue printing
- Cut the filament
- Poop
- Continue printing
- Remove the nozzle from the right head and put it away
- Grab and dock the nozzle associated with the blue filament
- Load the right head with blue from the AMS
- Cut the filament
- Poop
- Continue printing
- Grab and dock the nozzle associated with the yellow filament
- Load the right head with yellow from the AMS
- Cut the filament
- Poop
- Continue printing
- Continue printing
The tool changer takes 16 steps and the H2C takes 32 steps. The difference in time is significant and the amount of waste is dramatically different.
The H2C requires an AMS retraction and retrieval for each colour change that isn’t on the left tool head and a poop. The tool changer doesn’t need either unless the filament changes in any docked head during print.
The H2C can use one fixed filament and six changeable filaments, each requiring an AMS swap and poop. The H2C can have even more materials in use with multiple AMS units connected.
The tool changer has as many available filaments as it has docked heads. The Snapmaker U1 has four and the Prusa XL has 5. There are other printers available with more. None currently support an ANS style tool, but that is likely as every company has is is about to launch. Using an AMS style solution will increase the swap time though.
The biggest differences is the print time which is often half or faster than a H2C, the amount of waste is far greater as every swap requires a poop.
If you want fast colour prints with the only waste being the prime tower then a tool changer is the only solution.
The other thing to consider is that a larger format tool changer allows more heads, thus more filaments available per model. This is an exciting direction for 3D printers.
I loved my IDEX, it could print using both nozzles at the same time, albeit each one only occupying half of the build plate (left and right). This meant two identical or mirrored models at the same time with no downsides.
The other benefit is the price. Snapmaker U1 has made a solution that is less than half the cost of the H2C. The build volume is smaller on the U1 though.
I love Bambu Lab printers, I am disappointed they produced the H2C as it is an expensive solution in the wrong direction. I feel they wanted to raise the cost of the flag ship printers rather than truly innovate.
