Hi all as the title says, I’m toying with buying and H2C but for a specific reason.
I currently have a desktop laser but it takes up so much space and in all honesty I don’t use it as much as my printer but I do still need the laser for the odd project.
My thoughts process is that the h2c obviously has the faster colour changing facilities as well as more colour options via AMS. The other thing is I can take up less space and have a potentially bigger working area on the laser bed.
My worry and my question is, I’m looking to see who uses the h2c for both 3d printing and laser work? I’m concerned on how much mess the laser leaves behind after a job and does it affect prints afterwards?
I’ve watched a few videos on YouTube but I don’t trust some of the creatures as I believe they will only give you positives in order to keep in with the big companies so I’m looking for some real world usage statistics as I don’t want to spend such an amount of money only to find it’s not going to be usable in the real world.
Also 10w or 40w? I will mostly only be engraving and mostly on wood.
If the rumored H3C is coming any time in the next 6 months, I would wait to at least see what that looks like.
Can’t speak to laser stuff though. I have the laser version of the H2S and haven’t used it yet. Thoroughly intend to do so though, as thin plywood is a great material for weight saving camper drawers and cabinets.
10W is more than enough for engraving wood though. I used a LOT less power ages ago with my old Trinus laser with good results.
Like others will say: wait a bit, till like december. Bambu is making a tool changer this year and Prusas deformed gutter child tool changer is being beta tested.
IMHO you could put the “laser” part in the subject to get more directly relevant feedback. A direct forum search about the laser functions could also be enlightening… folks tend to keep each other pretty honest around here… I don’t own the laser bits, though I do appreciate the utility of multi-functional tools in general.
Compared to what?
The H2C is a good (great?) printer, basically no regrets there (owned since last Dec.). But the whole laser add-on is essentially a completely separate function… including the software to use it (would definitely try that first for myself). Personally I wouldn’t want to burn anything in there because it’s a bear to clean already… sooo many surfaces and nooks and vents that are hard to reach… the whole Vortek rack, the $$ print head… no thanks. All that internal height and complexity just gets in the way, and also it is not a sealed chamber at all (large poop hole in back, hello), so it’s vital the exhaust setup can maintain negative pressure inside there. From an engineering standpoint, I just don’t see the two functions as being especially simpatico, and the actual shared components are relatively simple and cheap (gantry, steppers, belts, controllers… I did say relatively ).
I would caution anyone who wants an H2C to give thought to whether they are equipped and inclined to do precision electronics repair. Many H2s need service at some point, and unlike something like a P1S, it can be VERY involved and challenging with the H2. If you’re not prepared for that, it’s not the printer for you.
200% agreed! I haven’t logged in, in a long, long time, but I felt compelled..
I will preface this by saying I have 2 H2C units. One converted, one purchased after doing the conversion.. Both units have had to have heads replaced due to fan failures.. Both units, yes, Bambu will take care of you with the parts, BUT, it’s a pain.. And sooner or later, I think you’re going to have to do this repair.. And it’s a pain! Couple hours job.. And it’s not a “point and shoot” whatsoever.. I have less struggle with RC stuff, because I have the magnification equipment, soldering tools, etc..
Adding in a laser,I wouldn’t.. Especially with the software as disconnected as far as compared to the phone and studio apps for printing (I have the cutter attachment, and only used it once due to this)..
I like my printers(when they work), and I’m in it now.. But I am not looking to upgrade to H3, H4 or whatever.. I am just not.. I advise extreme caution throwing a laser in the process.. Just my .02 cents..
Hi all and thanks for the replies, I have read through everyone’s posts and I’ve came to the decision I will just hold off.
I was aware the new H3C was pending but I never seen anything about a laser option due to limited information at present.
Looking at things I will just stick to what I know for now as I really don’t want to be going down a technical route if the machine develops a fault. I’m fairly mechanically minded but I have enough issues in my daytime job never mind hassles with my hobbies too.
Really appreciate the feedback from people as it did help make my decision.
RC is easy because RC cars (hobby grade ones, not toys) are designed to be repaired and maintained with basic portable tools in a field. I do not think the H2D was engineered to be easily repairable (obviously they thought about it for their own warranty repair costs, but they did not spend extra to make it differently to make that very easy)
I’m not into cars, 95% helicopters and 4.5% I’d say planes.. I left card alone decades ago, and took to the sky.. That’s when it became “interesting” for me..
And to a certain extent yes, they’re designed for repair. But more importantly, they’re over designed for durability, safety, and to stay together.. I wouldn’t say they’re exactly easy (well, cars are dirt simple.. I wasn’t speaking about cars), especially when you’re repairing, or building. There’s a good deal that I took for granted, until 2 years ago when I began with ELRS, rotorflight and all that, that radio system entails.. Building the kit is the easy part(takes me about 3 days to throw a kit together), programming, setting up, and then dialing them in, so that they fit you, that’s the hard and time consuming part. But this have gotten micro sized.. The electronics..
But, cars, cars are the simple ones of all the RC segments.. That and off the shelf drones.. It’s easy to break down: if it stays on the ground, and basic, it’s easy, if you’re putting it in the air, basically you have to know something, and it’s going to take some time after the build.. That is, unless you’re doing speed runs with cars.. That’s it’s own can of worms, which isn’t easy either(as far as RC cars go).. And once you get into using threadlock, that immediately takes the repair ease, and throws it out the window..
You may reach a bigger pool of laser users by DMing some contestants of the Laser Cut contests. There were two. Here’s a link to one of them.
In any case, asking about user experience is like asking the six blind men what an elephant is like because each user’s experience depends on their own unique preferences, use case, expectation, skill level, etc.
I got an H2D with the laser. Much like you thought it might mean I could get rid of my standalone laser.
I thought it would be a great idea, but I’ve never used. Turns out I was too excited to buy it and overlooked 2 main reasons…
(1) the potential fumes (I run my standalone laser in a shed, H2D is inside). I know extraction is a thing and I could vent it etc. but even lasered plywood can really get smelly, and
(2) the worry of the mess and interfering with the 3d printing side of things. It’s always going to be 98% 3d printer and 1% cutter/plotter and 1% laser. Will definitely give the plotter/cutter a go at some point.
Now though I’m waiting for the mew H series printers. Could possibly sacrifice the H2D to laser if there is a proper toolhead changer coming.
I do like the look of the R1 but for all the laser work I do right now I can’t justify the price. I would love my laser work to pick up but there just doesn’t seem to be such demand over the 3d printers.
I got the A2L and bought the vinyl cutting attachment with it and I have to say I was pretty impressed but the software was a nightmare to navigate round, Purley because I’m used to Flexi when cutting vinyl but it’s handy to have as my vinyl cutter is large so it’s tucked away and brought out if I need it lol
Setting up ventilation is absolutely worth it FYI, even if you never cut, if you run ABS or ASA. Styrene poisoning really sucks and it’s pretty easy to give to yourself when printing that stuff. I suspect some people just hand-wave the symptoms and the rate at which 3D printer owners get it is higher than we may think.
Anyways, as far as the laser goes I also have one but have not used it yet for similar reasons.
