I have seen that the fix for
“This device cannot handle more conversations” on the P1S was simply to restart the printer, but that did not work for me.
In my case, I was running several instances of BambuStudio on 2 different computers.
The basement computer threw the “This device cannot handle more conversations” error and was stuck.
After trying every other fix, I finally went upstairs, closed out 3 instances of BambuStudio on that computer, restarted the printer and then the downstairs computer connected without the error.
The PS1 apparently cannot handle multiple connections to many instances of BambuStudio.
Just curious hut why run multiple instances? Ill occasionally get 2 - 3 running when Im looking for a model and I inadvertently try and open the file. I might have multiple New Projects going but all in the same instance.
Why run multiple instances of BambuSlicer?
Because I have 5 Bambu printers and they are all different models and plate sizes.
First of all, you are using “New Projects going but all in the same instance” incorrectly. Bambu supports multiple PLATES, it does not support having multiple .3mf PROJECTS with different settings open in a single instance simultaneously.
If I want to keep several .3mf projects open simultaneously, and also monitor those prints on my upstairs computer, the only way to do that is with multiple instances of BambuSlicer.
I also have a second computer in the basement on the same floor as the printers that I want to be able to walk over to and connect to any of my 5 printers. The P1S, in particular, has a hard-to-use LCD screen, and is much easier to control from my computer or the Handy App. These additional connections can result in additional “conversations” that the P1S’s lightweight microcontroller cannot handle.
The post is trying to save another user from having to go through all the troubleshooting I went through before discovering that the core reason for the “this device cannot handle more conversations” error is too many device connections.
Quick Follow-Up Correction:
You CAN monitor multiple printers from one instance of Bambu Studio by enabling Multi-Device Management, but that is not enabled by default. However, as of today, October 24, 2026, Studio still does not support having multiple independent .3mf projects open simultaneously within a single instance.
Bambu users have specifically requested project tabs for this reason. There’s a feature request dating back to December 2025, but as of now, separate projects still require separate windows or instances.
Also, if you have several different computers running Bambu Studio, and possibly also Bambu Handy on your phone, even if each computer has only one instance of Studio, you may still encounter the P1S error “This device cannot handle more conversations” because too many connections are being made to the printer.
I wasn’t being critical. People teach me new stuff all the time on the forum.
They have a software package on wiki that if something to do with people who have print farms. Maybe that would help
Thanks. I’m not quite at that stage. Five printers is still pretty manageable using the stock package. It would be nice if they would implement tabbed projects though.
