Hello, I have p1s and p2s printers and i wondered if it was possible to have them start on a timer of some sort, I am about to buy solar panels for my home and i am keen to find a way to have them start automatically in the morning while i am still asleep. Is this possible?
With the standard Bambu Studio install this isn’t possible but there are other options such as BamBuddy or I think you can also do this with Bambu’s Farm manager both of which I have linked below.
You can use gcode start code block to add in some delay. If its midnight now and you want it started at 9 you can add this to the first line of your start gcode to delay by 9 hours, then just print now. Don’t save this to your config, or itll happen on every print ![]()
edit: uh oh nvm, Jon is right, see below. There may be other gcode solutions, but the injection vector is probably still right here
G4 S32400
From a power use perspective, steppers will be energized but no heaters will be running. Depending on your printer, fans might be. So more than idle but not nearly during print.
A more mature solution probably looks like homeassistant monitoring your inverter and enabling a smart plug, and issuing a command to bambu farm / bambuddy.
FYI Bambu’s max G4 is 90 seconds. You can get around by adding multiples.
G4 S90
G4 S90
G4 S90
etc
Not sure if you still need it, but I had the same need: starting prints at a set time (early morning in my case, because of the noise). I made a Mac app that does it: slice and send from Bambu Studio as usual, set the start time in the app, and the printer waits until that time before heating up. No LAN-only or Developer Mode, Handy keeps working. It’s called PrintAlarm 3D, you’ll find it by searching the name (new account, no links yet).
