Timelapse videoe files have wrong date and time in LAN only mode
It is not a big deal, but my X1 Carbon still thinks it is March 2024, according to the file date of the time-lapse videos. I believe the reason is that I run in LAN only mode. Can I set the Data-Time manually? I guess no.
Turn LAN only off, then on again?
Did you ever find a fix for this? I have the same problem. Date and time on videos are off.
+1
I am also interested in this.
I think you will have to leave LAN mode for at least a short time. Perhaps just long enough to reboot with access to the internet so that a time server can be contacted. Bambu does not provide a way to manually set the clock.
If you use the X1Plus firmware enhancement it is possible to access the printer’s Linux operating system via SSH and issue commands to set the time, time zone, etc. while in LAN mode.
Hey,
did you found any solution?
i have the same problem in the normal mode( not only Lan mode) with my A1. All video and timelaps video have a timing of 7 h in the future
