Hi all,
Im printing a hinged part, i want to print them standing up so i get perfect holes as this is where the pivot pin goes to hold the hinged parts together. But in doing so i need support enabled. When i remove the supports then obviously theres some clean up required to get the 2 parts to fit together nicely.
Also you will see on the middle part there is bit sticking out about a third of the way up, this is to locate the piece accuratly in an aluminium rail. This also needs support and then clean up to get to fit. When i print a test piece but orientated so it doesnt need support it fits perfectly.
Does anyone have any tips on how i can print these so that they fit as intended without the clean up afterwards?
Thanks
Dan
