Too much Filament?
Maybe nothing. Depending on the settings, sometimes they will spin fine other times you need a little force.
I’d try a little force, try wiggling each gear until you have some movement or hold the inside circle & try to force the outside circle to turn…JMO
Also, if you resized the model, sometimes that will cause issues.
