Hello, someone know if i can get a 5v on this plug ?
I would like to use a fan for the extruder, without a long câble.
Thank you.
Could I suggest just using a separate USB charger to get your 5v?
I get the urge to simplify wiring but the larger worry is the current that your fan will pull from that board and that’s effect on things. Never mind the risk of accidentally shorting it.
I just came off of a 3 week, $500 repair journey that I caused by my error in an X1 nozzle swap. I ended up replacing 3 boards.
FWIW, BL support was good and very patient
Yeah maybe a 5v separate usb is safer. Just ask in case it’s possible to work without this, because of the ugly câble ![]()
