Toolhead hitting / dragging across part suddenly
Hello,
Overnight my new X1C has developed an issue where the toolhead strikes and drags across the printed part, ruining the print. You can feel and hear the bed vibrate as the toolhead drags across the part.
To make sure this wasn’t a calibration issue, I ran the bed leveling and auto calibration.
Additionally, to make sure this wasn’t a slicing issue, I reprinted a gcode file that worked yesterday and it is now experiencing the same issue. I have tried multiple rolls of filament, including rolls that printed the same part without issues yesterday. Layer height is 0.18 which should be no trouble for this printer.
After that, I did the belt tensioning procedure per the Wiki, also to no effect. I also lubricated the z-axis screws.
Interestingly, first layer always prints perfectly, so I don’t believe it’s a bed levelness issue.
Hey jlew715,
I would next check the Bed Tramming Procedure to see if it way off or not.
Also check you tool head and nozzle is not loose and look at your motion system to see if anything is not normal.
Keep us updated :v:
Bed has been trammed. It was pretty close out the box; the nuts/screws ended up pretty much where they started after tramming.
Unfortunately, the nozzle is still crashing into the print:
Some parts look like the X & Y belts are loose the waves on the right side
Belts
Some parts look like it’s not extruding do you have a backup nozzle you can test out ?
extruder
By chance is the layer getting bad first then the nozzle is making the noise as it crossover and this is why you think it’s hitting ?
Not sure what to do about the X/Y belts; I have done the belt tension procedure per the Wiki twice now.
The first layer prints normally, then during the second layer, the nozzle strikes the first layer as it moves across and kind of “bounces”. The gaps you see are where the nozzle is hitting the first layer, then it lifts up extruding a small amount, then hits the first layer again, etc. If you touch the side of the bed while this is occurring, you can feel a buzzing vibration only when the head is doing this “bouncing”.
Is it same pattern in same spot for different prints? Could there be contamination on the build plate thats causing first layer to lift into the nozzle path?
Straight edge your bed and no bubbles in your magnet ?
Orca Slicer or Bambu Slicer ?
What is your first layer height set to ?
Can you post all your settings ?
You said other filaments is doing it also correct ?
This is so weird - it just stopped happening. I did not change anything that I’m aware of.
You might have had a some filament stuck in your nozzle acting like a flow restrictor and your nozzle pressure was going high and low.
But good news is your up and running again woohoo :+1:
Just came accross this issue again on my X1C when running 100% infil on rectangular infill, if anyone has this issue again soon. Changed infil to concentric and all good, had a swap around to different infil types and again all good, soon as you swap back to rectangular it has a ■■■■ and drags accross the print.
