Hello,
So I’m struggling to get good top layer finish. I’m using PEI textured sheet, and first layer has that sparkling finish and that’s great. But top layer is kind of meh…
If I use ironing I get half mate, half glossy finish, If I leave everything on default, I can see lot of lines and maybe some under extrusion on some parts.
Does anyone uses some extra settings to get better top layer quality? If so can you share it?
Ty
I’m in the same Benchy (boat)
I got the same problem. What filament are you using?
i’m using Esun abs+ here but it also happens with pla and petg
I changed the to layer flow to 1.05 and now it looks better.
Yes seems an under extrusion
@email.utilizzo123 I know it has been a while but did you ever solve this? Getting prints that look just like your picture all of the sudden.
I use Bambu ABS and have calibrated all the colors I have. Black and Red had the highest flow just over 1 and lowest was mint at 0.907. The default profile uses 95% for their ABS. So it appears the colors matter too.
