The images are self explanatory but regardless of what model I try to slice, it would appear the top layer is not slicing properly so the infill is exposed.
I’m new so it could be my imagination but this only seemed to happen after i installed the latest update. Screenshot by Lightshot (gun) Screenshot by Lightshot (RC plane wheel" Screenshot by Lightshot “Tundra wheel”
Detailed description of the problem
Printer model used
Slicer settings used
Type of filament used
Photos that clearly show the problem
.3mf file (if the file can be shared)
Any potentially useful information that is related to the problem
Just a comment on the wheel is you may want to lay it down instead of printing vertical. Not much build plate contact area the orientation you are showing.
About the missing tops - any chance the layer slider on the right side of the Studio window in preview mode isn’t at the top? That can make layers look like they are missing when they actually aren’t.
There’s also some bugs in Studio than can cause weirdness for me when I load models into it initially. Any slices tend to leave parts out until I save and reopen Studio. Have you tried saving the 3mf, closing, then reopening Studio and reloading the model?
Sorry but for some reason the software used for this forum doesn’t work properly here in Thailand.
Many of the words and phrased are in Thai script and won’t translate to English with a right click, translate to English and I can’t add an attachment from my hard drive. Here’s an example of the Thai scrip showing this post. Screenshot by Lightshot
This is the best I can do for the issue being discussed but I actually printed this and it came out as the sliced image. Screenshot by Lightshot.
I just tried to slice with the Orca slicer and I’m getting the same results. So I’ve gone to my laptop which is still running the previous version of studio and the same thing is happening.
I’m at a complete loss as to what’s happening because all other programs on both machines are working normally. Im at my whit’s end.*
