Top player artefact
Hi, I’d like to ask for some advice on what I might have set up incorrectly or where the problem could be.**
The top layers don’t look very good — not nice at all — and I don’t know what’s causing it.
I’m using Bambu H2D material, 6 mm nozzle, 0.3 mm layer height, and the printing temperature was 255 °C.
Calibration was done before printing — everything from the bed to the flow, etc.
Does anyone know what could be causing this?
https://drive.google.com/file/d/1-8RDUb8avgu_HZp9zrbh-XBa03t7QAxA/view?usp=sharing, https://drive.google.com/file/d/1RiYFFpgYJ7rG1YLpgGI43mu9v9O_X3Az/view?usp=sharing
You can see the infill thru your top. (and it is grid)
How many top layers are you printing with? Try adding +1
Yeah the infill is showing from underneath. Go into the strength tab and add another thicker top layer. If you want the tops to be smooth you have to enable ironing in the quality tab. For me 75 mm/s with 25% flow works best but it is machine dependent. And to get those curves smoother leading to the top try .16 layer.
If you have ironing enabled disable it and make a ironing test
No ironing, and I set the top layer to 5, but the top still looks the same — the infill is still visible. I really don’t know where the problem is. When I get home, I’ll take a photo with the new print.
