目前在軟體中的支撐設定似乎只能有一種設定,例如我想在一個模型中使用2種或3種支撐的設定做不到,又或是多個模型分別放在不同的板中,好像也只能使用一個支撐設定~這樣有蠻大的困擾~這樣我必須把同為一組的模型分別儲存成不同的3MF檔案…而無法使用1個3MF檔案(裡面有多個列印板)~
[quote] At present, there seems to be only one support setting in the software. For example, if I want to use 2 or 3 types of support settings in one model, it cannot be done, or multiple models are placed on different boards. , it seems that only one support setting can be used
This is quite troublesome
In this way, I have to save the same group of models into different 3MF files… and cannot use one 3MF file (there are multiple prints in it) board) [/quote]
Roughly translated it says:
“Currently, there seems to be only one support setting in the software, for example, if I want to use 2 or 3 support settings in one model, or if I put several models in different boards, it seems that I can only use one support setting…this is a big problem…so I have to save the same group of models in different 3MF files…and can’t have to save the same group of models into different 3MF files… and I can’t use one single 3MF file (with multiple printing plates inside).”
Anyone can provide a solution?
