有的时候打印会遇到需要内嵌磁铁或者其他加强部件的情况,人工调整G代码需要一定水平,且具有一定风险;若是人工盯着打印进度,到达指定层高后暂停则容易错过时机。基于以上要素,是否可以在切片软件里增加一个可以设置在打印到指定的层高后自动暂停的选项?
Sometimes when printing, there may be situations where embedded magnets or other reinforcement components are needed. Manually adjusting the G code requires a certain level of proficiency and carries certain risks; If you manually monitor the printing progress and pause after reaching the specified layer height, it is easy to miss the opportunity. Based on the above elements, can we add an option in the slicing software that can automatically pause after printing to the specified layer height?
Fortunately you are arein luck, that feature is already available in Bambu Studio and Orca Slicer. After you slice your model browse to the “Preview” tab. On the right side is a slider where you are able to move up and down to see each layer. Move to the layer you want to stop at, right click the “+” slider, and click “Add Pause”. You will need to slice your model again after adding the pause and you can print as you normally would after.
非常感谢您的指导,我才知道这个“+”可以点击
Thank you very much for your guidance. I just found out that this “+” can be clicked on
