Hi All, I recently printed a model that combined TPU and PETG-CF. I loaded the TPU from the AMS-HT’s back port and ran it through the left nozzle normally through the back. It would only let me choose Bambu lab TPU. That seemed to work fine. In the latest Babmu Studio, I chose the filaments per their respective nozzles and loaded the filament profiles. Because TPU runs much slower, I adjusted that models print speeds. The problem with this is Bambu Studio wouldn’t let me slice it. Some online research led to a workaround where I would have to load the filament profile for PLA on the left nozzle. That printed, but the stringing wasn’t great. For this use case, it worked.
I have a couple of questions.
With the latest firmware that was supposed to allow printing from the left nozzle, why can’t I choose a generic filament vs Bambu branded?
Is multi-material printing with TPU not allowed on Bambu Studio? Is there a fix or perhaps a workaround using Orca slicer?
Just lie to it, if you want to get moving today. Create a profile that has all the tpu settings but is type=pla. Tell the ams it’s pla. It’ll let you do it.
I only dare to load TPU 95A to the right (induction / motionless) nozzle using the TPU Feeder.
As per Bambu wiki TPU and the left nozzle is not supported yet: H2C Filamant Printing Guide | Bambu Lab Wiki
Careful with pretending TPU is “PLA” or anything besides TPU to the slicer. If one looks at the machine g-codes, one can see exceptions being made specifically for TPU, and other exceptions for some filaments like PLA or PETG. This can be seen in conditional if/else statements in the code.
One important one is that the printer will skip dynamic flow calibration even if enabled or set to “auto” in the final print options – so make sure that’s disabled manually.
If lying to the slicer, “TPU for AMS” is probably a better type to use.
Which “it” are you referring to here?
“won’t let you” how exactly? Is there an error? The “slice” button grayed out? Did it tell you TPU can’t be used in left nozzle?
Here is what I’ve tried to do with TPU. When it is in the AMS-HT going out the back port, it is considered an external spool. I run it through the regular back left port, loaded manually. When I load a generic or Bambu TPU profile, Bambu slicer will not let me slice the file because the slice option is greyed out. I’m using version 2.8.2.61. This problem appeared in a multi-material print and the recent single TPU print I made.
To get around that, I chose generic PLA. I loaded my TPU settings into the PLA profile and made a copy. That worked. It printed flawlessly.
So how does the latest firmware support TPU printing when I can’t slice the file because a TPU profile is used?
Wait, so, this is even before the decision of which nozzle (left/right) the TPU will be assigned to? That doesn’t seem to make sense. If nothing else the slicer would just assume TPU goes on the right side. Are you assigning the filament to the left/right manually (custom mapping)?
Do you assign any material to the external spool slots on the printer, before all this? (That’s not required, just wondering.)
Can you attach an example project reproducing the issue?
