The fact that TPU is not supported in both hotends beggars belief. The fact this huge limitation wasn’t mentioned in the specs when I ordered the printer is a scam IMHO. And it would cost me over €100 to return it.
Allegedly the reason is the left hotend moving up/down, which is plausible.
Has anyone tried to overcome the problem or should I be the guinea pig? Looking at the video where they show the hotend switches, it looks like TPU could bend (instead of being push up through its extruder) when the left nozzle is raised. But is that always a problem or a mere risk? Also, will there be sensors so the printer says it’s jammed even if such bend doesn’t interfere with anything?
BTW what about “TPU for AMS”? I’m assuming that too is forbidden problematic? If not, I may find ways around this even though that filament is way harder than 95A.
Edit: Forget about “forbidden”, that’s trivial to work around. I’m talking “can it be used some way”.
That’s wrong!
I think you’re uninformed.
TPU is supported on the right hotend.
However, not in combination with an AMS or via the internal filament buffer.
The Bambu Wiki has a detailed guide for using TPU with the H2D.
I recommend you read this information: https://wiki.bambulab.com/en/h2/h2d-tpu-printing-guide
Logically speaking, the_Raz is of course right. TPU left && right is not possible/not supported.
It read to me as if TPU wasn’t supported at all, which is of course wrong.
People understand what they want to understand.
Yeah sorry for the confusion, I meant the fact I can’t print with two colors of TPU, one in each hotend. English is not my first language.
They neglect to mention this on the sales page. They mention multicolor printing and TPU printing - they don’t say “pick one”. It’s not even in fine print - I see no clue on that page about this. For me the whole point of upgrading from the X1C was using support filament without switching (which is supported), and dual color TPU.
Edit: Even that wiki page doesn’t mention I can’t use 95A on the left side, it only says that for 85A and 90A.
Anyway @simtom does TPU for AMS work on the left side without even fooling around with a mockup filament profile?
The way I read the original advertisement was that it was suggested to run tpu in the right nozzle. When I found out the left nozzle wouldnt even accept tpu, I laughed out loud. What a gigantic missed opportunity. If it cant do 2 colors of TPU, what was the point? Is what I said in my head. Just a heads up, alot of people here are going to troll you if you dont agree. Fanboyism and whatnot.
Dont worry about digger, he only shows up to downvote. Never actually says anything.
If this is accurate and based on the fact both extruders appear identical, it seems purely arbitrary for BL to make only the right extruder TPU-worthy. This is especially true if you have to rewire the teflon tubes for the job (and do so differently between 85A and 90A TPUs!). You don’t want to muck with both if you don’t have to…
As an aside, since the published TPU printing guide doesn’t explicitly call out AMS TPU or 95A, it sounds like those should work fine in the AMS 2?
Yes, no need for any mockup filament profiles. It’s treated as if it were PLA.
Only TPU for AMS will work in an AMS. 95A needs to be placed on the external spool (or any other external holder) and has to be inserted using the TPU bypass port.
