TPU to PETG filament change questions
I am trying to print something with my A1, I would like the first several layers to be TPU and the rest PETG, mostly for aesthetics, but also durability.
I know TPU cannot (should not, because TECHNICALLY you can make it work) be used in the AMS lite, so I would start the print manually with the filament on the spool holder, and ideally at the proper level do a filament change via bambu studio after the model has been sliced. i have never done a color change via the slicer like this…or of any kind actually.
I guess my question is, will the printer automatically use the ams based petg filament after printing filament that was used external to the AMS lite?
If I have to manually unload the TPU and manually hang and feed the PETG on the spool holder, will the print pause at that level automatically?
I am mostly concerned that the printer will try to use TPU settings to print PETG, assuming I can even get that far…Or will I have to somehow manually set settings after I change filaments?
I guess, what happens step by step when a filament change is put in via the slicer? Is the filament change via the slicer just for the AMS lite? More or less how do I change from TPU to PETG so the printer uses the correct filament profile to print each filament?
Basically explain this process like I am 5 years old and have no idea what im doing.
Thanks!
This will work. When you setup a model to have multiple colors or filaments the slicer handles most of the details.
You would select say TPU in filament one slot and that when applied to the part of the model you want would make sure the TPU filament profile is being used when that filament type is in being printed.
Then you select the PETG in filament two slot and apply it to the proper parts of the body and just as above the printer knows, when it switches filament it also must switch a number of parameters for proper printing, bed temp, nozzle temp, flow rates etc…
There is the complexity of one being an AMS filament and the other not, this means manual changes will be required, the printer will prompt you when necessary.
I would finally say to search this on google to find a good overview of someone who made it work well, did they massage some parameters like bed temp or did they just run with the defaults? I don’t know.
yeah i tried searching this. One source was way more involved than I wanted (involved editing gcode) and the others were older posts with answers that dont really apply anymore due to various updates from Bambu
TPU will not work in the AMS without modification ps that Bambu Lab (BL) doesn’t warranty against.
You will not in the filament guides that TPU is not compatible with the AMS.
If you are hoping to utilise the AMS for this process, you may prefer to wait a couple of weeks as a new product is due to be launched. It is quoted as “flexible material for the AMS”.
Without more details, we can only speculate that this may mean Bambu Slicer (BS) may gain the ability to combine these two materials with ease.
Fingers crossed.
I am not specifically hoping to use the AMS lite for this. I just have never done a multi material print that wasnt petg/pla.
So I dont know how it would work if I have to manually feed both the TPU and the PETG from the spool holder, or if the printer will know the PETG is in the AMS lite and would automatically use that when the time comes.
I know I can either put in a filament change or pause when the model is sliced, i am just not sure what that does. Does the filament change mean from one ams lite filament to another? from an external filament to an ams lite filament? from external to external? The pause, does that just simply stop the print, and then continue what it was doing before it paused? Does it ask if anything changed before things continue? if im printing TPU externally from the spool holder, then pause it, retract the TPU and put in PETG, will the printer know its a different filament, or will it ask me if its a different filament?
These are all things im sure the wiki explains, or i could figure out using a test print, but struggling in forums is definitely more my speed.
I understand completely.
I will be playing with TPU on a printer later today for a different reason.
I will try it out as I am interested in the answer. I will be using the PAUSE method and without an AMS in the mix.
I will report back on my results.
I am trying to find time to test.
I have found this video in the meantime.
You may wish to look as if this guy has succeeded.
I found this video too, but I still have issues to get this print done.
Btw. there is an update video for PETG and TPU from this Guy.
My problem is, that I may do not understand this in detail.
I have a simple cube, spitted into two parts and I can assign two filaments to it.
Bottom part: Bambu PETG
Top part: Extrudr TPU
Where I struggle is…
Bambu PETG has its settings like print temperatures, volummetric speeds, PEI Plate temp and so on.
The Extrudr TPU has also its own settings.
The problem is, that I need to create a Dummy TPU with a combination of PETG settings and TPU Settings.
For TPU, the bed temp for example need to be set with settings of PETG, but volumetric speed and such, from TPU. Got it. (or correct me if I am wrong)
And now, the Issue I am facing…
In Bambu Studio, I can set both TPU and PETG via EXT. and send it to the Printer. So far so good.
I printed the PETG part, and reached the PAUSE I set at a specific layer.
I went to the printer and unloaded the ext. PETG.
But I cannot load the ext TPU from X1C’s Display Menue!!
It is simply not selectable. In other words, I cannot change the filament and therfore the settings still stay with the PETG settings and especially with different filament flow settings.
What is wrong? Please let me know.
INFO:
I am running the following versions:
Bambu Studio: 2.1.1.52
X1C: 01.09.00.01 → 01.09.01.00
I have exactly the same problem. Bambu Studio has no unload option on pause.
Assuming this is related to external spools.
An upcoming feature is meant to make swapping external spools as easy as it is with the AMS.
They have not said if this will be per layer or multi changes within single layers (thus would take ages and be annoying).
I do not know when this will be included though.
I have done this a few times with my P1S, PETG item with built in TPU gasket.
You need to modify the filament profile with a lower flow ratio so you can print both materials with the same profile. You slice, then put in a pause at the layer you want to swap materials, then manually load the new filament. You dont change the designation of the material on the printer, it thinks its printing the same materials the whole time. When you are printing the PETG you can adjust the temp if needed and turn on Ludicrous mode to speed things up with the lower flow rate.
Unfortunately, when the printer is paused, there is no option for unloading the existing filament.
You go to extruder function and do it manually. Can only be done with external spool by the way, not with AMS.
If this type of TPU could work with an AMS, there would be no need for this workaround. Unfortunately, it could not.
I think I am missing something, because on my P1P there is no option to unload the filament on pause. So, I cannot do anything manually, short of using scissors.
As I said you go to extruder and do it manually. It should work on all bambu printers, when they are paused you can manually feed the extruder in either direction.
Thanks. That makes sense.
That is good news. Where did you find this information?
Here:
It was announced as part of the BS 2.2.0 beta.
I do not use this, but the multiple references to fixes suggest it it available in current versions.
Amazing! Many thanks!!!
I will try it this week.
Apparently I need to wait for a firmware update. :frowning:
