I’m thinking I got the wrong printer for me at 74 yrs. old
I spent 7 hours trying setup the printer, WI-FI, Bambu Studio and Studio finding the printer.
Putting the printer together was easy and running setup, I don’t know why videos show that and not connection between printer / computer.
I didn’t print anything, I’m trying use a file from Thingiverse. Don’t I have to be able to see the SD card in Studio
I don’t want to use a phone unless it’s land line
Is LAN on the printer ON or OFF? It’s OFF. You would think the printer would have a USB port.
The return 14 days are ticking away.
Thanks
I am 68 years old, I had some issues with wifi connection but I moved the printer closer to my router and that was fixed.
Once your wifi is connected, when you slice a plate , chose SEND from the drop down menu where it says PRINT PLATE - then click the SEND button to put the file onto the printers SD card without printing - from that point you can print that file directly from the touch screen.
Good luck - when you get it sorted, printing is easy as long as you have a well sliced file.
Have you successfully connected the printer to wifi and can see it in the bambu studio?
To print you need to login in bambu studio
To print a STL file you need to
go to top left corner and click “File”
Select “new project”
Click on
click on top right
After slicing is complete hit the “Print Plate”
This is an old post, I don’t know how I reposted it.
Sorry
I did get it working, I have 130 hrs. on it now.
Thanks Everyone
