Tree support interface
As I understand it in the latest upgrade Bambu Labs has inserted a layer between the top of the supports it inserts and the overhang it supports… The purpose of this is to make it easier to remove the supports from the overhangs. I have just printed an object with a significant overhang under which Bambu Labs inserted a significant number of Tree support. Apparently between the top of the supports and the overhang a cross-grid layer was inserted. This indeed significantly improved the removal of a series of 50 tree supports (in mass as the inserted layer peeled right off and took the tree supports with it). However after their removal the surface of the overhang that the inserted layer was in contact with was really rough and a reflection of the grid structure of the inserted layer. I’m not sure the trad off of inserting that layer (which saves me the work of removing individually each tree) offsets the sanding I must now do to even the surface of the overhang. Is there any control of the inserted layer ( to make it less of a grid) or a way of stopping it from being inserted?
