Tree supports are solid
Hi all,
I’ve been using Bambu Studio for a few days with my P1S printers and I must say it is working well.
I decided I should try move all my slicing over to BS.
I have a few Creality CR10 V2s.
I’m not sure if I am missing something but when using tree supports on the CR10 they are being sliced/printed 100% solid. I don’t see any setting differences between the P1S (the supports are generated correctly here) and CR10.
Thanks for any advice.
Ok, so I see the ‘Base pattern’ is basically the infill of the tree. For some reason the spacing was/is set very small for the CR10, changing this or making the pattern default resolves the problem.
Capture1
Thanks for sharing! Same issue when trying to use the S1/V2 profile on CE3Pro.
