This is an image of a 4mm thick white flat surface with about 6mm wide black squares. This surface was printed down where the black is 1mm thick. Both PLA
The print looks good but under closer inspection the black is slightly hourglass shaped. The black is well mounted so this isn’t a big issue.
Just wondering if anyone knows how to eliminate the shrinking or hourglass in the black squares.
