Fairly new to all this so be gentle!
I have a model which is too big for my A1 Mini build plate, but I can split it in BS and print as two halves which is fine. The problem I have is that if I add text before I split the model I can’t then edit the text at a later date when I re-open the .3mf file. If I don’t split the model I can edit it as normal. What am I doing wrong or is it a quirk of BS?
I know I can split the model and then add text that seems to work OK but it makes it awkward getting spacing right between the halves., and before anyone suggests it I don’t have the physical room for a bigger printer, so it’s not an option.
Thanks for any help
Hi Brian,
Assuming the text has a split through it, I’d say that was expected behaviour. If you think about the two scenarios, with the un-split model, you have the text placed on a single object / part. When the model is split, the text is no longer across one object / part, so it can’t be edited across two objects / parts.
I think you’ve already come up with the answer, either split the text into two parts (might be a hassle getting it to line up, but should be a one off job to get it right - if you have the left half of the text right aligned, and the right part of the text left aligned). Or can you split the object so it doesn’t interfere with the text?
Good luck!
Hi Dave thanks for the response. Sorry I should have been clearer the text isn’t split it’s just the model itself.
Imagine a plaque for a door number as the model with the two numbers as individual text items one on the left and one on the right. the split is on the plaque right down the center between the two numbers.
I can get round it as I said by splitting the model first but it just seems odd that the seperate texts should be affected like this.
Does it become one object similar to if you have used a mesh boolean rather than two objects with a text_shape , ? (nope
It allows for some editing (painting) but not the text lettering , for that you would need to delete the text shape in objects and re-add it
Yup thanks for looking into it but that’s confirmed it for me, it’s not possible it’s a bit naff but I’ve split the model first now and saved that so I can use as a template for future use.
You could try a feature request , if it possible
Latest feature-request topics - Bambu Lab Community Forum
good shout I’ll try and phrase it better ![]()
They say a screenshot is worth a thousand words , i also neglected to mention the movement and orientation tools work too, i found mine facing the wrong way and upside down (cut east to west)
feature request and screenshot submitted ![]()
BTW BrianT, If possible, you might try splitting your model into 3 pieces and install locating pins on each piece in the design so when printed, they align perfectly. The only issue I have had with this is that if you print the pieces at different temps, they may not line up very well.
Thanks the problem isn’t the allignment it’s if I wanted to make changes after the split neither BS or OS will allow you to do it. It just means you have to make sure you have all your text correctly spelt before the split otherwise it’s start all over again.
My project is a thin background model with multiple collumns and rows of text, too thin in fact for any kind of physical join but for my purposes that’s OK. hopefull the ability to edit after split will be added in the mean time I just need to be carefull ![]()
