Unable to set K value and since 1.06 now defaults to 0.000
Not even sure this is my problem, but I did rule out bambustudio update as the issue. I rolled it back and problem continued. I don’t have the problem on my P1P’s, only my X1Cs after update.
In studio, when I select the filament type, I have no PA Profile (nothing in dropdown) and Factor K is grayed out. It shows 0.000
Anything with close parts like this, will fuse together now. (Flexi Factory Frog)
You can see after slicing there are gaps, but the back left leg is fused on all 3 joints. This wasnt a problem previously and they still print properly on my P1P.
What am I missing here? What can I change to help with this?
The problem went away after changing the nozzle. Makes no sense though as you can see both the right and left leg have the same clearances and the right leg would be fine, while the entire left would be fused… either way, problem solved.
