Machine: X1C + AMS with Cool Plate (Machine has 1030 hrs and I have not replaced anything, just regular lubrication and cleaning)
Filament: BambuLab PLA Matte Ivory White (Opened a day ago, and I have a new desiccant in my AMS)
I’ve recently had a lot of trouble with under extrusion on the second layer for flat, larger areas. I’m printing a site model for a class, and I’m trying to conserve filament with a very thin bottom part of the model(one bottom layer and then a second layer for sidewalks and such)
The first layer has been going down fine with no gaps, but the next layers, specifically the second layer, has become a huge problem because I need it to be almost perfect, and it’s coming out all under-extruded. I’ve tried calibrating the flow and pressure advance numerous times, whether manually or trying the auto features. I’ve tried turning the flow all the way up to 1.032, which made little to no difference; I tried stock 0.98 and the auto-calibration, which set it at 0.97. I’ve tried slowing down the top layer to 80, and still, the same problem. I’ve tried other filaments, and again, the first layer goes down great, but the second layer does not.
I’ve retightened my belts, done self-calibration, tightened the hardware securing the hotend, and there are no kinks in the PTFE tubes. I regularly clean the build plate and apply a thin layer of gluestick. I checked the hotend and there still appears to be thermal grease on the thermister and heater, which was something I saw mentioned in another thread.
I’ve done at least ten cold pulls and gotten some junk and black debris, but this doesn’t explain why the first layer goes down perfectly and the second doesn’t. I would expect that the clog would affect the first layer as well.
I’m kind of scratching my head right now because it’s never been this bad before, and the problem only crept up recently. Immediately before this problem, I printed a decent amount with the white PLA+ from MicroCenter, my understanding is that it’s eSun PLA+ rebranded, so I don’t think I’ve been putting any garbage through the machine, and I really only print with PLA, no CF or anything abrasive. I have also updated my BambuStudio and X1C+AMS to the latest firmware versions, but this error didn’t seem to coincide with any of the recent updates.
Any help is great!
