Under extrusion on supported overhangs
My PLA prints are coming out beautifully except for under-extrusion on overhanging surfaces printed on a support structure. Extrusion looks perfect everywhere else. Here’s my current settings and the results. Any advice?
the only way i’m getting a decent surface quality on bottom walls is by printing on support filament with 0 z distance and 0 top interface spacing (rightmost part). i understand physics is against me here, but the under extrusion in these areas with any other support settings seems fixable.
Anyone? Someone on the Facebook group said they have the same issue. We’re yet to find a solution.
I’m facing the same issue here. No one has a clue?
Try using 3 interface layers instead
ever found a solution?
Hello ! I have the exact same issue,
I tried tree support with 0.2 Z offset, the surface on top was very under extruded.
I tried then normal support with 0.1 z offset, the surface still looks bad…
I would prefer to print with a 0.2 z offset to ease the removal of supports, but I cannot get a good quality of my part :frowning:
Is there anything I can do with Bambu studio parameters ?
Regards
