This is my first printer so I’m not entirely sure if what I’m noticing is normal or if it can be improved. Basically flat surface supported area looks textured. Is there a way to refine that surface through bambo handy settings? pic attached
That almost looks like you still left support interface attached.
It sure looks like that! But I’m using the white support Bambu filament for the interface. And it’s just popping off nicely. I thought that so much so I tried to cut it out with an exacto knife and pliers. Nope. It’s the print.
Then I’d say the Z spacing between print and support interface is too big to get a proper layer squish.
I had it to a single layer but I switched to 0. I’ll report back when the print is complete.
which setting is this exactly. I do not see the layer setting? Yes advanced options are on.
