Understanding the visual encoder calibration results
As pointed out by one of the youtubers (I’m forgetting now which one), the first time you run the visual calibration plate, you are provided with results which some the improvement in accuracy after the calibration vs. beforehand. You would think that the improved calibration would then become the new baseline, and so if you were to run a second calibration immediately after the first, there would be little to no improvement. However, that doesn’t happen. Instead, the reported improvement results for the second round of improvement seems to be comparing the second calibration against no calibration at all.
Is that what it’s doing, or is there something else in play that would explain the larger than expected “improvement” after the second calibration?
Round one gives positive and negative values around the set flow ratio.
Round two only goes from zero downwards.
Means you pick from the first batch what looks the best and has a tiny bit of over-extrusion.
Don’t go for the number that looks a bit too thin on the infill lines :wink:
Second round will then use that value and provides patches with a LOWER flow ration.
Problems always start when people take the Bambu instructions literally…
Then you end with a good looking first patch that might already be wrong one to pick…
I think we’re talking about different things. My bad. I should have used the proper term, vision encoder calibration tool:
I just now changed the title of the thread to hopefully clear up the confusion.
I did do the calibration. It says „completed“ but I did not see any corrections? Would be interesting.
I printed some special test parts which I will analyze optically. I did print the part before and after calibration and I‘m curious to find out the difference. The method is very accurate and can also be used to measure accuracy of sheet metal parts.
Yes, VMM is actually the right tool to verify the positional accuracy across the build area. Unlike the checks other users here are talking about
That’s interesting. It definitely used to report the amount of improvement on the printer’s console (what you call the HMI) when it was done.
I’ll try running it again, and if it’s still there, I’ll photograph it so that we’re all on the same page.
Meanwhile, based on my previous test (sample size of 1), it did indeed seem to perform as expected within the advertised tolerance:
This is where I was able to show the improvement on a print that was already properly shrinkage compensated.
I’ve run the calibration back to back, and the results are always similar. The “fix” is always around the 200um.
There is a wiki if you want to understand why can be critical for engineering accuracy.
For normal user, this is not really critical, not worth spending that kind of money.
Similar principal like gaming mouse optical tracking sensor accuracy.
As mouse can return the pointer back to exact pixel on the screen.
Think of the toolhead is the mouse and the Vision Encoder is the mousepad.
I just now ran two tests back to back, and the information is still there on the HMI.
Here are the results of the first run:
and here are the results of the second run:
I’m currently running the beta firmware, but it provided the same type of summary information when I ran it with the official release firmware.
I guess somehow it retains a memory of how things measured prior to any calibration at all, and so it compares each new calibration to that memory? That seems to be the literal interpretation of what it is saying. i.e. rather that using each new calibration as the baseline and comparing each new calibration against the most recent prior calibration. Or maybe each new calibration first flushes the prior calibration, and so every time it’s as though it was the first time. I’m guessing maybe this.
Whatever it is doing, it seems the results are highly repeatable!
Interesting. So we can plot that over time to see how the motion system would change with increasing print time.
My personal goal for the printer is that the contour of any part will always be in a +/- 0.1mm band.
In general:
  1. the larger “improvement” you see, the worse “mechanical” condition your machine is at. the improvement can be also read as error.
  2. doing a belt tension adjustment usually helps a lot to reduce mechanical error
  3. vision encoder would deal with the rest, but it’s still better to have a mechanically more accurate machine.
My printer was having 150um average improvement (or, error); after belt adjustment it reduced to <80um.
Like other calibrations, it resets previous calibration before doing the new one.
The simple way to think of it is that with the video encoder calibration, the center of the nozzle will get placed with an accuracy of less than or equal to 30 micron of where it theoretically should be. If shrinkage happens after that, it’s not the fault of the vision encoder calibration. A recent video by Aurora Tech seemed to confuse the two.
It seems like your best hope for getting that would be starting with the vision encoder plate then, as without it the results indicate mine would have been out by as much as 0.306mm.
I’ve had good luck dialing in the shrinkage compensation pretty tightly after two or three iterations. Well enough to meet your plus/minus 0.1mm requirement.
I think I should give the belt adjustment a try :grimacing:
The vision encoder calibration by default is run at ambient temperature. I wonder if the belts would expand enough under higher chamber temperature that we should be running the vision encoder calibration at working temperature instead?
The bigger question is what are the best tests we can run to confirm that the vision encoder calibration is working correctly and delivering the promised results rather than just rely on it to tell us whether it is or not. i.e. how do we know whether it’s telling the truth?
Print some test geometries and measure it with a Zeiss coordinate measuring machine…
Do you have access to one of those?
This is a conundrum. If we heat the chamber to working temperature, then the vision encoder plate itself is going to expand and no longer be accurate. I guess we’d need different ones that are calibrated to be accurate at different temperatures, or else compensate using measured temperature and a known co-efficient of thermal expansion?
Yes, thats why I bought it. The larger the parts you print, the more pronounced the errors will be. How did you compensate for shrinkage? So far I never did that; if I needed accurate prints I did 2 iterations print, measure, correct and reprint.
We do have one in the company I work for, so maybe yes.
What would be really cool is that if bambu used some of the technology that they used for the high accuracy nozzle offset calibration and made a test that would then adjust filament profiles for dimensional accuracy.
