Hi All
New user, been having fun with my A1 for about a month, learning a lot. Starting to get some consistent quality prints but was having random defects in the outer layer, so after watching some video I thought I would try changing the wall order. Outer layer first gave me AMAZING results, but it has a few defects that seem to be based on my setting changes, help me understand why.
Bambu PETG Gold filament (was opened a week ago, dried 9 hours at 65C before this print)
A1 with AMS Lite
0.4mm Hardened Steel hotend
Using the 0.16mm High Quality Profile with Outer/Inner wall order, outer walls slowed to 50 mm/s
I also changed the Travel Distance threshold from 1mm to 2mm (as recommended in some random video). I have already removed this option.
Don’t cross build area enabled
Gyroid infill
Default Seams
So basically I’m just trying to understand why this is happening, and is there a way to fix this by changing some settings? Or will this always happen on this print because of the way the design and slicer paths?
TL DR
It appears the defect follow the seam line. Can you help me understand why these settings are causing these defects?
Thanks in advance
