I had a huge print that used the entire print area. My print stick to build plate no problem. However the corner of the print pulled the plate up from the heat bed. The plate if not being printed lay flat on glass table and the heat bed is also straight and square. It is the magnetic adhesion not strong enough to fight the pulling force from the print especially the corners.
In the pictures taken from front left and right corner. You can see the plate lifted up. This also caused inconsistent lines showed up on walls because layers were compressed.
I’ll look into using clip to hold the plate down in case I have something like that in the future. But there might not be enough room because the edges are too narrow on a couple sides. Does anyone know if changing printable area or extruder position in printer profile can actually move the print area?
Unfortunately that’s physics working against you. It appears that the magnetic force at the corner is unable to overcome material shrinkage, however bed adhesion is able to withstand it leading to the effect you observe. If there was any space there I’d recommend using clips to help keep the buildplate to the bed, but there’s naught but a sliver of material there…
As @Johnny_Bit mentioned, there are limits as to what is possible.
The clips you mentioned may be able to help (space permitting). Other than that, a warm chamber and low layer heights (at least the lowest say 5cm) can help to combat warping further.
So glad to see this posted here, I have the same problem. In my case the object being printed was 219mm x 227mm, so not even the entire A1 bed. It lifted the build plate about the same distance as the picture the OP shows. I wish the magnets were a little stronger in the corners.
I might have room to use some type of clip like you guys are mentioning here, anyone got a link to a good one I could print? many thanks in advance…
