Studio does not try to print at 10,000 millimeters per second.
The highest print speed set by that profile is 300 mm/s for Inner walls. The 10,000 numbers are acceleration rates, stated as millimeters per second squared. These numbers haven’t changed in years and are well within the printer’s capability.
Using default settings and PETG turns out perfectly for me.
But I also have my AMS filled with alumina desiccant modules which pull the RH down to a cool 0%. No blobs, zits, and only the finest little wisps of strings on occasion.
In fact, I can run it at 124% speed too with no discernible differences.
If you are willing to try it, exceptionally dry material might (its possible you have something else happening) make a huge difference. I have a small advantage in that I am also an injection molder by trade so I have a lot of experience drying plastic.
With enough good quality regenerated desiccant you can essentially pull the RH inside your AMS or drybox down so low that you achieve industrial quality drying. FAR below the “10%” most of the 3D printing community reccomends.
Here’s my method.
Using activated alumina or molecular sieve desiccant (buy some if you dont have any) you have two basic ways to go about this.
Using an AMS, print some desiccant pods to hold your desiccant. A funnel to go with them helps. The more desiccant you have the better.
Run a dry cycle on the AMS, whatever duration you are comfortable with.
About 2 hours before the dry cycle finishes, regenerate your desiccant on a flat tray in the oven or a toaster oven if you have one at 200C/400F.
10-15 minutes before the dry cycle ends, pull your hot, regenerated desiccant out of the oven. Place the hot tray somewhere safe and let it cool for a little while.
Immediately after the dry cycle ends on the AMS, fill your desiccant pods (make sure the stuff is cool to the touch!) and then quickly shove them into the AMS while the filament is still hot (that’s important!).
Give it an hour and watch the RH reading plummet. Give it a couple more hours to confirm it does not start creeping back up.
If you do not have an AMS, I assume you have some kind of drying solution. Create yourself a drybox solution (if you dont already have one) and print some desiccant pods appropriate to fit in there with your spool.
Essentially do the same thing as above, however you may need to use your oven to heat/dry the filament roll. If so, regen the desiccant and put it into the sealed drybox before running a dry cycle on the filament. It will be fine in there for a couple hours.
If you are using the oven as a dryer, you dont want that burning energy for 8-12 hours so use it to preheat the filament roll for about 2 hours, then drop it into the drybox and wait a day. If you have a filament dryer, use that on a full cycle first.
Personally, I printed my desiccant pods out of PPS and can simply toss the whole pod straight into my oven for regeneration. A full set with alumina desiccant for my AMS 2 can hold my filament in the AMS at “0%” RH for about a week before it starts slowly climbing as I swap rolls here and there. I have no idea how long it lasts if I just leave the AMS closed.
Unfortunately your P2S cant print PPS, but it just means your desiccant regen process is slightly more work.
These steps here. @Short_Shot is right - if it’s moisture. I would also bet it is, though.
You can tune out some water effects when printing with filament with higher moisture content and slowing down the print is one way to do that. It gives the water a little more time to leave as the filament heats as it enters the extruder.
Only thing I would add to what he said is desiccant in an AMS or dry box works great but you have to keep track of it. Get a hygrometer in there too and regenerate or replace your desiccant when the humidity gets above around 15%. That’s not exact but since fresh desiccant will be much lower than that, you’ll have a while anyway before you even need to worry about it.
But desiccant with its own high water content can donate water to filament that is more dry than it is. That’s why you need to keep an eye on it. It can go from big help to big hurt if you don’t.
I don’t understand why an existing saved project (or profile), with modified properties (like speed) would get reset values under a new version of Studio. Even when selecting a new base processing profile (like “0.20mm Standard…”) modified settings should still be transferred (make sure “Automatically transfer modified value when switching process and filament presets” is enabled in Preferences, which is in “User” tab in recent versions).
Non-modified settings would indeed get changed if the selected profile was also updated during a Studio version update.
Now sometimes they do add some new setting which could affect/break existing projects, like the most recent “initial layer infill” and “sub-top surface pattern” additions (w/out defaults which auto-match any existing project, AFAICT). Which indeed is rude and bad. But that doesn’t seem to be the case in this instance.
Also I just want to point out that the process presets don’t take the filament type into account at all. Which IMHO is unfortunate. Instead they seem to rely on the filament “Max volumetric speed” setting to limit speeds overall (not per feature like in the Speed process settings). And of course that doesn’t affect acceleration settings at all.
One quick way to get lower speeds in the process presets is to pick a finer “quality” preset which starts with lower speeds/accell., and then tweak the layer heights & line widths to what is actually desired (and also support interface spacing to match one layer height, if that is relevant).
Not saying the default got treated well, but none should break prints this way.
Looks to me clearly resembling a clogged print.
And even the 2nd picture with normal result, extrusion consistency already looked to be in a pretty rough place.
Why is it clogged? Many things can clog it, but default profiles shouldn’t. Moist PETG are likely not the reason either. That’ll be the troubleshoot part for you.
What I’m seeing: severe under extrusion on the surface; lines that are likely designed straight but aren’t. Lines wobbles when direction/speed changes.
I’m not familiar with P1S’s toolhead assembly, but seeing these problems I’d suggest check the motion system: loose screws around the nozzle (which will clog it), belts etc.
You mean a clogged nozzle? A clogged nozzle does result in severe under-extrusion, but you hear the extruder slipping if that is the case. Also, severe under-extrusion results in flimsy, gossamer-like prints - or at least visible holes in the vertical sides. These parts are strong, no side defects.The top surface defects I put down to the gooey nature of the hot PETG and the ironing process, which never impressed me as being great for PETG or most materials - nor does it concern me greatly. I’ll keep an open mind and see if any screws are loose, in my head or the printer head!
