I can’t figure out how to upload from Tinkercad at all. I used to just make it into a .stl and upload into octoprint after using a slicer. I’m so confused.
It’s very similar. Export the file from Tinkercad as an STL. Import or drag this file into Bambu Studio. Slice and send to the printer.
Thank you. For whatever reason in the Bambu Studio the upload button does not work. The model literally disappears when you go to slice and it errors out. I have to drop it in from an open file. Very strange
The upload button is to publish your BS model to MakerWorld. . There’s the add icon (top left) or File >> Import works. Or, what I do is just drag from Win Explorer into BS plate and it’s there.
Correction–it’s the add icon that’s not working. It shows up on the plate but then when I hit slice it kicks the model out. However, when I drag it in it is perfectly fine.
