I want to load one model to Makerworld with two different print profile and print plates. First plate is the main model with basic default pla profil. Another plate is screw with different infill and wall profile. Should I send them separate profiles or can I upload the hole model with one profile? How to do that? I assum it will takes another profiles to both parts if I upload it in one profile. I havent done this before…
You can have per plate and even per-object settings. So you simply change the settings you want for the object on the 2nd plate and upload the model as a single profile with 2 plates.
Actually, if the items fit on the single plate and there’s no color changes it’s fine to have items with different settings on same plate.
Thanks for reply. I will try that.
