Hey Folks,
The Auto Refill function is very handy during longer prints. However often enough i have the problem that poorly wrapped/filled spools will have knots and therefore get stuck in the AMS and the motor cannot pull anymore. Then i have to either manually remove the knot or cut the filament and replace the spool with a new/other one. I work in an industrial field and when this happens at like 5 pm i will lose a whole night of printing even though i have the complete AMS full with identical spools.
Feature Request:
If the AMS Motor cannot pull the filament of a spool anymore (for whatever reason) then just ignore this spool and switch to a similar one (like the AMS would do when the filament just normally runs out).
This way i can come to office in the next morning and inspect the issue with the old spool but i do not lose 16 hours of printing time.
What do you guys think? Advice is very welcome
+1, this keeps happening to me too.
Setup: P2S with AMS. Auto refill is on, and a matching backup spool (same type and colour) is loaded in another slot.
A few times now, an overnight print has paused with 0700-8007 “Failed to extrude the filament” when the active spool ran out. Each time the tail was taped to the core, so the end never came free and never passed the AMS runout sensor. The extruder stalled against the tape, the printer treated it as a clog, and auto refill never ran, even though the backup spool was sitting right there.
A fix that seems simple: when an extrusion failure happens, check whether the active spool is probably almost empty (the RFID remaining estimate, a percentage set by hand, or the feed motor’s load) before treating it as a clog. If it is, treat it as runout: retract, switch to the backup slot and continue. If the backup slot also fails to extrude, it’s a real clog and the printer should pause as it does now.
Bambu has said the tape is meant to let go at the end of the spool, but it doesn’t always. Without this, auto refill only works with spools whose end comes free, which leaves out most third-party filament.
