When I saw the FTS at first, I thought that it doesn’t matter at all anymore how you connect the AMSs, the switch takes care for you. Of course it does not work like that. But I didn’t expect the limitations I describe below.
I have an X2D with 2x AMS2 + 1x AMS HT. One AMS holds all PLA, the other holds PETG and the HT is my hot spare for engineering materials, extra colors, external spool holder for TPU and simply for drying.
My hope was that for any print with at most 2 filaments (2 colors, 1 color + support) from different AMS, the printer can keep both filaments loaded throughout the print.
When I went through my usage scenarios, I realised that however I group those 3 AMS, there are always some scenarios that don’t work out:
- single filament from any AMS on the main nozzle
- PETG from AMS-B on main nozzle, PLA as support from AMS-A
- PLA from AMS-B + extra color from HT on other nozzle.
- same for PETG
- TPU from HT on main + PLA as support from AMS-B on aux
- TPU from HT on main + PETG as rigid from AMS-A
- PLA multicolor from AMS-A + HT
However I would group my 3 AMS onto the 2 inputs, half of my scenarios above don’t work out.
I found that having both AMS2pro on the main nozzle and the HT on the aux nozzle without the FTS actually means the same amount of manual spool swapping, so I have almost no benefit and potentially have to deal with the extra friction.
And on top of that when you have installed the FTS, you can’t use an external spool holder for loading TPU directly into the nozzle. So printing TPU with the FTS would be really cumbersome.
What is really missing for me in the FTS is an input for each AMS that can be assigned individually to both tracks. And then I found that exactly that exists in the model I linked above, although manual switching only. Still this is very fast. You just flip a switch, go into AMS configuration and drag’n’drop the flipped AMS to the other nozzle. Takes maybe 10 seconds total.
This allows me optimal configurations for all the scenarios above, I don’t have the extra drag, no cascade of 4in1-adapters dangling at the back of the printer and 50€ saved.
I’m sure with an H2C and more AMSs, the situation changes and the switch gains usefulness, but even then, a switch with one input per AMS would be much better and what many hoped for like me, when they first found out about the FTS.
So once the idea is in your mind, every lesser solution is a disappointment, even if it means an improvement over the situation without FTS as you pointed out.
And the FTS adds quite some complexity to deciding your setup.
One thing BBL could improve by software to achieve the same goal:
Allow to connect multiple FTS, using 4in1 adapters after the switches to join the outputs for each nozzle.
That way you could connect 8 AMS to 4 FTS and assigning each AMS individually to a nozzle.
And the golden solution would be an AMS that already has a switch integrated, so that each roll can individually go to 2 outputs, one for each nozzle. So all you need is to join all the outputs from your AMS into the two nozzles by 4in1s without any extra devices. This would make it completely irrelevant how you distribute filament across your AMSs.
