Useless Support Lines on first layer
Why are these support lines there? They are supporting nothing. I’ve also tried to exclude these zones around them panting custom supports.
Any help is appreciated!
I noticed the same thing on a recent print - support prep that never gets support printed on top of it.
If you adjust the support angle setting you may find a value that lets it actually put support there.
I suspect it’s a bug in the slicer that somehow adds unused support prep.
Luckily it isn’t wasting a lot of filament but if you can’t get rid of it with support settings might want to file a bug report.
First of all, thank you for responding. Changing the support angle threshold didn’t solve my issue, but your response prompted me to investigate the support settings, and I found an alternative solution.
Disabling ‘on build plate only’ removed those support lines on the first layer, but it added other supports that I didn’t want. So, I enabled ‘Don’t support bridges,’ and those supports were removed, except for one. I removed the remaining one using ‘Paint Supports.’
I achieved the desired result this way. I’ll still report this bug as soon as I have time.
Thanks again!
