This repository is dedicated to storing presets that have been meticulously crafted and optimized for use in 3D printing and slicing applications. Whether you’re a 3D printing enthusiast, engineer, or designer, our collection of presets aims to simplify your workflow and elevate your 3D printing experience.
Thanks, please feel free to contribute or just send me your presets and I will add them ![]()
Sir, you are a star, thank you so much for your effort.
Thanks! Please also share your presets to expand the list even further. You can also send me your profiles and I add them.
Howdy, happy to share mine, however mine are build around Custom Filaments in new Bambu\Orca, so presuimable you want the BASE filament and its Parent Custom filament as well? OR ???
- basically how do you want them sent \ what parts
These .json in the \filamnent folder have very little info.
These \filament\base “parent” fiilament files have majority of the important stuff, but in the case of above Red,Green, Blue, White - they are just a sub-preset of the parent “Sunlu PLA+” below.
Just to be clear why I am asking, the other filaments in your repository mostly “inherit” from other existing system filaments, so these will work for other people downloading them, however without my parent, my SUNLU PLA+ , my SUNLU PLA + B.GREEN etc will not, nor if you just posts the parent filament, will the people get all the different colour presets etc.
example existing from repository.
Does anyone have profiles for Creality Hyper PLA and Hyper PETG series. These are the only known branded filaments and I can not find any profiles for them. Even official Creality site only mentions 600 mm/s print speed for PAL and 300 mm/s with PETG. They do not even mention approximate recommended Max Volumetric Speeds.
Thanks.
They will be at least a good starting point for our own calibrations. They only have Creality hyper PLA atm. No profile for Creality hyper PETG yet.
The site is rather new i assume. Filters are not working, it glitches when changing pages, etc. I checked several random filaments and some do not have all the information. Site will be a good resource when things begin to come togather.
I only have acces to Creality filaments as know brand. I have to use locally produced ones. I contacted manufactures and asked for profiles they use with BL printers while testing their products. None replied back yet. I will calibrate and create my own profiles for all. I may add them to this site as well.
NB: This is about https://3dfilamentprofiles.com/ (and not the user presets github project) but the user&post it was quoting from above has been deleted.
I poked around the site some more, as far as I can tell it has 1500 filaments and zero profiles. It does have “technical information” section (not profiles) which is usually blank, and it doesn’t seem to even have the capability to upload a profile.
A bunch of the technical info appears to be simply copied from the spool (like nozzle temperature 190-220C, which I guess is OK since it isn’t profile) and the color hex are just what the manufacturer supplied.
Yeah, I found the same. No real profiles but tons of Amazon affiliate links. Also taking in to consideration the person who posted it is the site owner, and he joined just to post it ![]()
I dotn get it is this about my post ?
Nooooo! Your post is just fine! Last night someone bumped this thread with a link to a site that was mostly affiliate links and no real profiles. That’s what krellboy and I were referring to. It looks like it’s been deleted now. Sorry for the confusion.
thanks for this it is perfectly described by your first sentence
meticulously crafted and optimized. just browsing now.
@Nahimic, Do you have preset for PLA as well, or just PETG?
Hello @Nahimic do you mind adding them directly to the repo ?
I know there are no profiles for the X2D. Will the X1 or P2S filament profiles work? Are profiles for the X2D coming?
No one submitted any profiles yet. You can adjust the profiles yourself and make them compatible with the H2D, but don’t expect them to be perfect.
Be the first after recallibration to submit these to the repository.
