Using AMS when exporting and printing GCODE-files (not 3MF!)
Okay, thank you very much. I´m working on Mac though and I have no idea how to “Close the 3mf file”. I used “The Unarchiver” to change plate_1.gcode, but I don’t know, how to get it back to an 3mf file.
I made it work. I just ziped the folder and then changed it from .zip to .3mf.
But if I load it into BambuStudio it says that it doesn´t work and there are no Model data. What did I do wrong?
From the post I linked above.
I’m not familiar with mac but as mentioned by @JonRaymond and @Ukdavewood you need another zip-app. If python is not a comfortable way for you, I can suggest trying 7-zip (Download) or some online JS based zip-app, like this Zip Manager.
I seem to be having a similar problem (with the P1S) - what is your exact error message?
This I think has led me down a much more likely path than anything else I’ve found on the internet. My use case is that I have a 3-color model that is printed multiple times with a different color for one of the 3. The total number of filaments I need are 6, but only 3 at a time, and 2 of those are always used. I am using OrcaSlicer. I slice a print and send it to my printer: prints fine. I save that very same file using the “Export plate sliced file” option (it’s saved as a “gcode.3mf” file), close out of OrcaSlicer, open it up again, load that “.gcode.3mf” file that was saved, and try to print. The printer prints any of the colors if they are 1-4, but then when it gets to color 5, it freezes at the poop chute. After waiting about 5 minutes, the printer sends me the following error: “Failed to get AMS mapping table”. My hypothesis is that the numbers of the filament at 5 are problematic for the AMS because there are only 4 slots, and they’re problematic because something isn’t able to interpret the metadata properly when sent from a .gcode.3mf file, but it is proper when sent from a normal .3mf that has the model still in it.
The best method I’ve found of using more colors than your ams handles is to lie to it, paint the thing up in only 4 colors, and add a pause at the first layer after you’re done with a filament being used. Swap your filament in the ams bays. Resume. It’ll only look stupid on the screen. Set an alarm, don’t let it stand paused for too long.
Imagine a rainbow cube. Roygbiv. Paint it in the slicer as roygroy. Pause after g, physically replace the spool that would print r with b, o with i, y with v. Press resume.
Thank you all! I needed to adjust some layer heights and got it to work on my Mac using tips here. Here is what I did:
  1. In Bambu Studio: after slicing, File > Export plate sliced file (Cmd+G).
  2. Rename .gcode.3mf as .zip file
  3. Extract locally and edit the Metadata/plate_1.gcode file (e.g., change layer heights) and Save.
  4. In Zip Manager (linked above), drag and drop the .zip file to open it
  5. Nav into Metadata folder, remove plate_1.gcode and add back the edited one
  6. Nav back up to and download the new .zip. Rename .zip to .gcode.3mf
  7. Open in Bambu Studio, confirm new layer heights (and any pauses you had set)
  8. Send to printer
