Using e-Sun Wood filled Filament
I have tried e-Sun wood filled 1.75mm filament in my P1S and get very stringy parts. There are fine fibers all over the parts and I cannot seem to reduce this by modifying temperature, retraction speed, printing speed etc. Does anyone else have experience with this material? I have two spools of this that I would like to be able to use.
The colorFabb wood filled filament seems to work well without these problems and I have just ordered more. Using the same colorFabb settings for the e-Sun wood does not work.
Did you manually calibrate the filament profile?
I experimented with a sample spool of wood filament and had to do a lot of calibration before I could get it to print well. Unfortunately I deleted that profile because it demonstrated to me that here was no really good use-case for me for wood filament. In particular, I was looking to see if I could stain it like real wood and that is not the case. I was also underwhelmed with the appearance. To me it looked more like Matte wood-colored filament not true wood.
You can pray, you can dance if you want to, you can leave your friends behind…
You CANNOT keep wood filament from stringing.
Nothing to add. I’ve printed a bit and no matter what it will always string.
Pro-Tip: If you want to print with wood get the appropriate color brown and tell people it’s wood filament. Almost no difference.
I haven’t had e-Sun Wood yet. Sunlu Wood Low Temp. and that was pretty good. Here I only had to print at the lower temperature limit (185-188°C) and only printed figures, so everything was very slow. There I noticed that it tends to print more poorly with prolonged use. The usual: Threads, fuzz, poor printing results in general. Must therefore be dried before printing or sometimes in between. It may also simply take longer to dry than you think. However, I have achieved the best results with small figures using this wood filament.
The last wood filament I had was from Creality and iSANMATE, where I also had to reduce the flow from 0.98 to 0.89 - 0.92. And I also had to dry the print temperature well down to 200°C (I didn’t try any lower) despite this.
I did manually calibrate the filament and could not remove the stringing. I did not do an exhaustive experimental design to determine which parameter was having the most effect but when I switched to colorFabb wood filament the problem did not occur.
Thanks for the information. I have had the best success with colorFabb wood filament. I am not drying my filaments at the moment but I guess that is something I should try. I am in Boston MA and the humidity has been fairly high. Today for example (Oct 3) it is at 80% outside.
