Using PETG & PETG-HF in same print
I have some PETG black left on a spool and then I will have to use the new PETG-HF. Can I start a print with PETG and when the spool runs out replace it with PETG-HF? There is not enough old filiment for a reasonable print but it seems crazy to throw away usable filament?
Any advice appreciated.
Thanks
Shouldn’t be an issue, but you might notice a slight color change.
Slight colour change not a big issue. Will it pickup the HF from a different AMS slot automatically or will I need to load it and then tell it to continue?
you’d have to lie to Studio to have it auto switch.
Would be more reliable if you just switched manually.
