What I am getting at is why you dont invest into improving your filtration system?
It seems like a more all around solution.
Because I DIYed an exhaust system. For more details read this https://forum.bambulab.com/t/toxicity-of-filaments/10287/23?u=dwdesigns
You have HEPA air purifier and window opened. PETG and TPU are low to moderate risk. You probably should be fine. But it can depend on individuals’ sensitivity to pollutants.
I asked Google to list some common filaments by order of risk. Here’s it for future reference when you may print more types of filaments.
Filaments are ordered below from lowest to highest overall health risk. [1]
I find it interesting that you chose to ventilate the whole room instead of going down the route of ventilating the printers.
It is simpler (no ducts and hooks) and more complete solution than only venting the printers. I can have as many printers in the room as I want and don’t need to add to the system.
Mon imprimante H2S se trouve dans ma cave… j imprime du PLA mat ou pure, de l ABS, du PETG, du PC et du PBT principalement…. Je commande l impression depuis mon bureau au rez de chaussée et je ne descend à la cave que pour récupérer l impression ou changer de bobine…. J imprime 4 à 6 fois par semaine…. Je suppose que je ne cours aucun risque?…
Probably low risk maybe approaching none?
Thing is fumes and particles in the air don’t all disappear when prints finish. They linger and take time to dissipate/settle (but particles can be stirred back up just from air currents as you enter the room).
We don’t really know the risk but exposures are easy. Minimize exposure to minimize risk whatever it may be.
But nobody here is likely able to tell you what risk there is in your setup. What we can say is there is probably some but we don’t know how much.
Merci beaucoup, je vais quand même prévoir une filtration de l’air…
I know this is a bit of an old post but I came here looking for discussion of print quality issues with PLA Pure and figured I would mention it here. I bought a few rolls for a project (a set of measuring cups) and the print quality is absolute garbage. The default settings in Bambu Studio are VERY wrong, and i had to dry the rolls for 16 hours and calibrate each color individually for it to even look SOMEWHAT decent.
I’m printing on and X2D–and struggled to even get basic shapes to look right. Over extrusion, under extrusion, gaps, surface imperfection, awful layer lines–I went through almost an entire roll in attempts trying to print a ~100G model.
All that to say–i would NOT use it for prototyping, at least not yet. The default filament profiles that come with Bambu Studio just are not there yet.
Good luck!
I already went though 4 rolls of PLA Pure white and is now on the 5th roll (orange). Printed on X1Cs. I have used the default profile for both PLA Basic and PLA Pure, both worked out fine. The Basic profile prints faster than that of the Pure profile, so I may use the Basic profile more going forward.
I don’t dry PLA. The PLA is used on the outside spool holder and subjected to room RH which varies between 67-70% depending on the day and time of day.
In terms of flow calibration, I run it whenever I change a roll, even if it is the same type and color. I may also run it if it was raining outside in case the extra moisture changes the printing property. I don’t do manual calibration, but just enable the option on the printer to let it auto calibrate.
