Hello everyone,
I’m having trouble saving the variable layer height in the current version of Bambu Studio.
Regardless of whether I use the right slider or the automatic mode, the changes are either not saved at all or are saved in a modified state.
Does anyone have the same problem and know a workaround?
For example my modification:
After saving and reloading it looks like this:
Best regards,
Rolf
Did you click the “Adaptive” button to actually do the variable calculation/update?
Then just click the toolbar icon again to close the settings pane.
I had done this for the automatic calculation, but often it still saved an incorrect value. However, I’ve now found a workaround for manual adjustment using the right slider. If I use Shift and the right mouse button once after adjusting the slider (smoothing), the value is saved correctly.
