Hello everyone
I have a question. can I insert 2 different types of supports on one body. I want to use the tree supports in one place and support the normals in another place. Is there any way? Thank you for your help
you can, you just need to go to objects instead of global on the process section, and choose your objects setup individually
edit/ just saw you mention you have only one body, in this case you can achieve this by adding modifier objects, and then following the same as above
edit2/ i actually went to test it out, and unfortunately it looks like you can’t after all, it works for fuzzy skin but not for supports with the modifiers
Not at the Laptop atm but I think theres an option for “hybrid” supports.
