Hello, just tried the latest Bambu Studio 1.10.0 with the scarf setting enabled by default. It seems to work well, but getting a lot of very fine stringing over where just the scarf seam runs. I’m using Bambu Matte PLA on the default high quality setting. Interestingly, have been using this setting and the same material with the previous version of Bambu Studio 1.9.7 (without scarf enabled) and the results are perfect. I know people will say it’s a temperature or retraction issue, but as I mentioned this has been printing perfect with the previous version with using just normal seams. The only difference is that scarf has been enabled. The stringing is not a major issue as it easily wiles off, however it is annoying and does get everywhere. Since then a newer version 1.10.1 has been released which disables scarf as default.
Any suggestions as to why this only occurs when scarf is on or is if just a natural symptom of that feature.
Apologies if this is double posted, tried earlier but don’t think it went through.
